Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Using Encoder 8 or 9 as SRC
        • Axis Flag update rate
        • Encoder Velocity
        • Evaluation Underflow error
        • How to receive ASCII data
        • INTCAP
        • Reboot in startup program
        • Use of AXIS format
        • User Variables
        • Using Encoder 8 or 9 as SRC
        • What is the axis velocity
      • 9000 (Legacy)+
Using ENC8 or ENC9 as a source (e.g. CAM SRC or GEAR SRC) on an ACR8010 or ACR8020 will cause an "OUT OF RANGE" error when using the syntax of "CAM SRC AXIS0 ENC8"
To solve this problem use the Encoder Position Register for that encoder instead.
example: CAM SRC AXIS0 P6272
Encoder Position Register (Encoder 8) - P6272
Encoder Position Register (Encoder 9) - P6288
