Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How can I check the axis PPU setting?
      • 9000 (Legacy)+
      • Encoder Velocity
      • Evaluation Underflow error
      • How to receive ASCII data
      • INTCAP
      • MFLOPS vs. MIPS
      • Reboot in startup program
      • Use of AXIS format
      • User Variables
      • Using Encoder 8 or 9 as SRC
      • What is the axis velocity
      • Axis Flag update rate
The PPU of an axis is Stored in a Axis Parameters (P12288-P14199), i.e. Axis0 has its PPU setting store in P12375.
You also can check the PPU by using the following immediate mode command from the ACR card prompt.
When Axis 0 is attached to program 0 as axis "X" you could use "PPU X" when at the Prog0 prompt, else use "AXIS0 PPU" from any other prompt.
