Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Software - Using the Com6srvr as an ActiveX (OCX) component.
Motion Planner's Communications Server is an OLE object. It can be used as an ActiveX (OCX) component, but requires a wrapper. The Motion Planner CD contains an installer in the Communications Server directory for the ActiveX (OCX) Wrapper and instructions on how to use it.
