Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SE Motors - Specifications
The SE motors have the same specifications as the SM series motors. The SM series motor specifications can be found in the pdf file at the bottom of the SM series introductory page.
http://www.parkermotion.com/products/SMSeries.htm
The SE motor is an economy version of the SM series motor. It features an external encoder with a plastic cover instead of the aluminum housing used with the SM.
