Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv to OEM010 Connections
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Below are the connections between the Dynaserv(except DM1004B/C) and the OEM010.
DYNASERVOEM 010
Step+45Step+1
Step-46Step-7(GND)
Dir++5V(w/1KOHM*)Dir-NC
Dir-19Dir+2
Servo On+24Shutdown+16
Servo On-23Shutdown-7(GND)
*Connect Dir+ of the Dynaserv to +5V with a 1 Kohm resistor in between. You can connect the Dynaserv's Dir+ (Pin 20) to the OEM010's Dir+ and Dynaserv's Dir- to OEM's Gnd (Pin 7). This will cause the Dynaserv to go counter-clockwise when given a positive command signal instead of clockwise.
