Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Windows 2000 locks up when printing
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
When printing from our MS-DOS based applications on a computer that uses a network printer, Xware 5.1 and Motor Sizing and Selection 2.9 will lock up when printer port is not captured correctly.
Note: [ENTER] denotes pressing the "enter" key on keyboard
1. Select START => PROGRAMS => ACCESSORIES => COMMAND PROMPT. This may be different on some operating systems.
2. At prompt, type NET USE LPT1: \\servername\printername [ENTER]
3. To verify that command was successfully implemented, type NET USE [ENTER]. You should see an entry that corresponds the information that you just entered.
To have this automatically performed every time someone logs in, it will be necessary to create a batch file and place that batch file in the STARTUP menu.
IF YOU ARE UNSURE HOW TO PERFORM THIS, PLEASE CONTACT YOUR IT/IS DEPARTMENT.
