Search
Sign in
Aerospace
Climate Control
Electromechanical Group
Filtration
Fluid and Gas Handling
Hydraulics
IoT
Pneumatics
Process Control
Sealing and Shielding
Parker Indego
Blogs
Forums
Knowledge Bases
Aerospace
Climate Control
Filtration
Hydraulics
IoT
Pneumatics
Process Control
Parker Indego
Blogs
Forums
Knowledge Bases
Search
User
Site
Search
User
Home
What are the SL motor magnet bar weights?
More
Cancel
Members
Sub Groups
More
Cancel
New
Virtual Engineer
Gearheads
Servo Motors
General - Calculating rotary and electrical power
MPW Motors - Does the MPW work in salt-rich environments?
MPP/MPJ Motors - Feedback data made available to the user when using Hiperface DSL in MPP servo motor (feedback option 6H)
BE Motors - Full Specifications
BE Motors - BE and SM Encoder Change
BE Motors - BE23 Brake Option Length Adder
BE Motors - G winding specifications
BE Motors - IP Rating for the BE Motors
BE Motors - MS, GS, PS & TQ Mating connector - SM & BE motors
BE Motors - Replacement of BE motor with Q encoder option
BE Motors - Temperature Wires for BE 16 frame motors
BE Motors - Wire gauge (AWG) For BE Series Motors with Flying Leads
Cables - BE, SM, NeoMetric/J Cable Options
Cables - Cable Kits
Cables - Drawings for Flying-Lead PS cables
Cables - Environmental specs for PS cables
Cables - MPM to MPA or MP-FLX or BLOK or SFD Drive Cable Drawings
Cables - MS feedback cables for ViX/Aries and Compax3
Cables - PS Cable Specifications
Cables - PS Connector Kits
Cables - PS Connector Specifications
Cables - PS Connector Wiring Pinouts
Cables - PS Motor Cable Wire Gauge
Cables - Replacements for Discontinued Cable Sets
Cables - VIDEO: How to find cables for Parker motors?
Cables - What are the height dimensions of the Parker Style PS connectors?
DX Motors- Servo Wheel weights (discontinued product)
EX/EY Motors - EX Cable selections for CE/ATEX and UL models
General - Checking Servo Motor Phases
General - Customized Servo Motors
General - Delta vs Wye phase connections
General - EME (Europe) motors crossover to EMN (North America) motors
General - EME (Europe) Parker SMB SME SMH MB ME MH motors
General - Grades of steel used in servo motor shafts
General - Hall Sensors: 60 vs 120degrees
General - Industrial servo motor output shaft diameter modifications
General - Industrial servo motors in low temperature applications
General - Industrial servo motors in vacuum environments
General - Linear Motor Sizing
General - Linear Servo Motor Parameters
General - Magnetic fields and Servo Motors
General - Mechanical Time Constants for Servo Motors
General - Minimum temperature of the Servo motors
General - Motor Connector Pinouts
General - Operating Temperatures for Servo Motor Brakes
General - Rated Bearing Loads for Compumotor Servos
General - Servo Motors: Checking Servo Motor Phases
General - SL Magnetic Force.
General - Smart Encoder vs. Absolute Encoder
General - Testing Encoders on Compumotor Servo Motors
General - Thermal switch specifications
GM Motors - Replacing Bayside GM gearmotors
HDX/HDY/HJ Motors - IP Specifications for Hauser HDY, HJ Motors
HDX/HDY/HJ Motors - Specifications
Kit Motors - Frameless Kit Motors (Inspection Report)
Kit Motors - Bayside Brushless Kit (K series) motors FAQs
Kit Motors - Frameless Kit Motor windings
Kit Motors - Frameless kit motors in extreme environments
Kit Motors - How to use Motion Sizer for K series Frameless Kit motor applications
Kit Motors - Kit motor cross reference overview
Kit Motors - Kit motor mounting best practices
Kit Motors - VIDEO: How to Integrate Frameless Kit Motors
M Motors - MS & PS Mating connector for the M Series Motors
MPM Motors - Converting from older MTS to Current Part Numbers
MPM Motors - Encoder Option 1 Software Setup for Vix Drives
MPM Motors - IDC B-Series Replacement Options
MPM Motors - MaxPlus (MPM) Resolver Option 1 Connection for Vix Drives
MPM Motors - MPM Motor Specifications and Performance
MPM Motors - MPM Number of Motor Poles
MPM Motors - Recommended replacements for MPM72 series: NeoMetric N070
MPM Motors - Trap Option: Use Sine as a Drop-In
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (230VAC Encoder & Resolver) to Parker MPP
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (230VAC Hiperface) to Parker MPP
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Encoder & Resolver) to Parker MPP
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Encoder & Resolver) to Parker MPP (640 & larger)
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Hiperface) to Parker MPP
MPP/MPJ Motors - Crossover of Allen Bradley Rockwell MPL series motors (460VAC Hiperface) to Parker MPP (640 & larger)
MPP/MPJ Motors - Motor Weights for MPP190 and MPP270 frame motors
MPP/MPJ Motors - MPP motor right angle PS connector dimensions
MPP/MPJ Motors - Replacements for MPP / MPJ servo motors with 3E encoder option
MPP/MPJ Motors - Thermistor
MPP/MPJ Motors - VIDEO: Parker's MPP Servo Motors
MPW Motors - Crossover of Allen-Bradley MPS to MPW Stainless Steel series motors
MPW Motors - O-Ring seals for front of MPW Stainless Steel servo motors
N/J Motors - Difference between NeoMetric size 70mm and size 34
N/J Motors - J series speed/torque curves
N/J Motors - MS, PS, & TQ Mating connectors
N/J Motors - Pinout for the N092 Motor (MS18-5) Connector?
N/J Motors - Replacements for NeoMetric / J series with Q encoder option
NM Motors - NM17 NM23 NM34 NM42 Servo Motor Specifications
P Motors - P Series Motors and Cables (Specs and Additional Information)
Resolver Cable Part Number Change for Servo Motors
S Servo Motors (from MTS-Germany)
SE Motors - Specifications
Servo Cable Selection & Drawings and Motor Pinouts
Servo model for Delta phase connected servo motor
Servo model for Wye phase connected servo motor
Servo Motor Cable Diameters & Bend Radii
Servo Motor Cable Part Number Change
Servo Motor Hi-Flex Cables
Servo Motor Replacement Information
Servo Motor Thermal Sensors (BE, SM, MPP, P)
Servo Motors: Absolute Encoders & Drive Compatibility
ServoMotor Current Units RMS vs Pk of Sine vs Trap
SM motor with Q encoder replacements
SM Motors - Axial pre load specifications of the SM motors.
SM Motors - BE and SM Encoder Change
SM Motors - Brake specifications for the SM and N0 motors
SM Motors - IP65 option with SM and Neometric motors
SM Motors - MS, GS, PS & TQ Mating connector - SM & BE motors
SM Motors - Powering the SM and N (Neo) encoders
SM Motors - Radial Shaft Runout for Parker Servo Motors
SM Motors - SM Flexible Cable Wiring Diagram
SM Motors - SM motor cables -TQ , -MS, -GS versions
SM Motors - SM Motor Order Code
SM Motors - SM motor T shaft option
SM Motors - SM Series 23 Connection Diagram
SM Motors - SM Series Size 16 Connection Diagram
SM Motors - SM speed/torque curves & encoders
SM Motors - SM/NeoMetric Encoder Specs
SMN Motors - Brake Specifications for SMN Series Motors
Standard resolver in MPM and MPP series motors
Ultramaster Motor files for MPN
Understanding Servo Motor Time Constants
Vacuum and Explosion Ratings
What are the dimensions of the additional tapped holes in my MPP motor housing?
What replaces Compumotor 23frame gearmotors?
What replaces Compumotor 34frame gearmotors?
What replaces Compumotor 92frame gearmotors?
What's continuous stall torque vs rated torque vs peak torque?
Where Are The Digiplan ML Servo Motor Specifications?
Step Motors
Linear and Rotary Positioners
Electric Cylinders
T-Slot Aluminum Framing
C3 + Xpress + ETH
Legacy (Discontinued)
Other
Share
More
Cancel
Home
Aerospace
Supplier Resource Center
Climate Control
Electromechanical – Mobile Forums
Filtration
Hydraulics
IoT
Mobile IoT
Pneumatics
Pneumatic Industrial
Pneumatics Mobile
Process Control
Parker Indego
Parker Indego Instructors
Parker Indego Therapists
Parker Indego Distributors
Community Blogs
Community Forums
Community Knowledge Bases
Below are the magnet bar weights for the
SL Series
linear servo motors.
SL Magnet Bar Weights (lbs)
2-Pole(42mm)
4-Pole(84mm)
10-Pole(210mm)
16-Pole(336mm)
22-Pole(462mm)
28-Pole(588mm)
LB043
0.23
0.47
1.17
1.87
2.57
3.28
LB063
0.38
0.77
1.93
3.10
4.26
5.42
LB102
0.77
1.55
3.87
6.20
8.53
10.86
LB140
1.10
2.21
5.55
8.88
12.21
15.55
Share
History
More
Cancel
