Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Resonance and the Dynaserv Notch Filters
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Even though the Notch Filter can be used in all modes of operation to minimize resonance problems, the Notch Filter adjustment procedure requires that the drive be configured for Position mode.
If resonance persists it may be necessary to use the 1st Order Lag Filter.
See the Dynaserv DM & DR Direct Drive Servos User Guide for additional information.
