Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Currently Released Gemini Drive Products
The following Gemini drive products are currently available from Compumotor:
PROFIBUS Option for any GV6 or GT6 power level
SERVOS
GV6K - Up to GV-H20
GV6 - Up to GV-H20
GV - Up to GV-H20
RESOLVER AND ENCODER OPTIONS
GPDM
STEPPERS
GT6K-L5
GT6K-L8
GT6-L5
GT6-L8
GT-L5
GT-L8
With the exception of the GV-U3E, these drives have linear motor capability. OS1.01, MP2.2, and a drive serial number greater than #99072100143 are required to run these drives with linear motors.
