Search
Sign in
Aerospace
Climate Control
Electromechanical Group
Filtration
Fluid and Gas Handling
Hydraulics
IoT
Pneumatics
Process Control
Sealing and Shielding
Parker Indego
Blogs
Forums
Knowledge Bases
Aerospace
Climate Control
Filtration
Hydraulics
IoT
Pneumatics
Process Control
Parker Indego
Blogs
Forums
Knowledge Bases
Search
User
Site
Search
User
Home
KH/KS Error 62
More
Cancel
KH/KS Error 62
Members
Sub Groups
More
Cancel
New
Virtual Engineer
Gearheads
Servo Motors
Step Motors
Linear and Rotary Positioners
Electric Cylinders
T-Slot Aluminum Framing
C3 + Xpress + ETH
Legacy (Discontinued)
Other
-E Motor Option
AC-03 / AC-07 / AC-10 / AC-15 manuals
Battery Replacement for 500 or JSI
C/CX Suggested Replacements
Cage Code
Changing the Configuration of the Compumotor Plus
Color Code for Stepper Motor External Encoder
Compumotor Plus motor internal potentiometers
Controller Cable Drawings
Custom Products
Daedal to Compumotor Cross Reference
Daisy chaining AR-C
DC Brushed Motor with the Aries & Gemini
Drive Input Power
Dumping the 3000 memory.
EDC TDC XDC VRP PMC
Encoder or Resolver?
Ferrite absorber
Heat Dissipation within Enclosures
How do I change the Btorq.dat file?
How do I download software from www.parkermotion.com?
How do I get support for my Parker SSD / Parvex division products?
How Much Power Do I Need?
Inertia Ratio
Is Parker Compumotor ISO9000 Certified?
KH/KS Error 62
KH/KS Motors
M-Drive/Motor Compatibility and Matching
Mating MS Connectors for KH motors
Motion Sizer: No motor/gearhead/actuator database error (No TS torque, Divide by 0)
My ARC-C or -D does not fit on my motor.
Obsolete Products -- 1990 - 1999
Obsolete Products -- 2000 and later
Offset voltage on the Compumotor Plus
Parker MotionSizer: Stationary Rack, Moving Pinion
Parker SBC Replacement products
PK130M Ordering Part Number Change
PK2 Part Number Change(5/9/97)
PMC Motion Controllers (PMC20 & PMC10)
Printing From Compumotor DOS-based Applications
QM Series Motor Information
Refurbished Inventory / Educational Discount
Setting the deadband on the VAC.
Software for the SV
Three wire prox sensor color code
Torque Margin
Transformer Specs
Upgrading A/AX Systems
VM15 and VM25 Terminal Breakout Modules
What is a single and two speed resolver?
What is CE, EMC and LVD?
What is difference between CD35M and CD60/80M?
Windows 2000 locks up when printing
Share
More
Cancel
Home
Aerospace
Supplier Resource Center
Climate Control
Electromechanical – Mobile
Filtration
Hydraulics
IoT
Mobile IoT
Pneumatics
Pneumatic Industrial
Pneumatics Mobile
Process Control
Parker Indego
Parker Indego Instructors
Parker Indego Therapists
Parker Indego Distributors
Community Blogs
Community Forums
Community Knowledge Bases
KH/KS Error 62
Error 62 is an undocumented error code.
It means "Excessive Peak Current."
You will see this if there is excessive peak current and pulses are incoming from the indexer instead of Error 61 which means "incoming pulses".
Share
History
More
Cancel
