Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What is the detent torque for Dynaserv motors?
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Detent torque is the amount of torque that must be applied to a motor to overcome the static (magnetic) equilibrium of the motor when it is in an unpowered state of rest.
For Dynaserv motors this value is typically 3-5% of the peak torque value of the Dynaserv motor in question.
For example: The peak torque value for a Dynaserv DM1004B motor is rated at 3 ft-lb. Therefore, the detent torque will be 3 to 5 percent of this peak value, resulting in a detent torque value of 0.10 to
0.15 ft-lbs.
