Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gemini - Downloading in
Q: Can you download programs to the Gemini GV6 or GT6 and/or execute programs while in "24V Keep Alive" mode??
A: Absolutely. In addition to diagnostic commands and feedback position information, you can download programs into the Gemini controller's memory, then immediately exectute that program or any other program in the GV6 or GT6's memory.
