Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Replacement Connectors for Dynaserv Products
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The CN1 and CN2 connectors for the Dynaserv DM and DR /drive motor systems are available for purchase from Connex. Contact Connex for availability and pricing at: 1-510-656-7722.
  • 50-pin Honda-type CN1 connector:
    - Connex part #: MR-50LM
  • 8-pin Honda-type Feedback Connector (for Dynaserv DR Series):
    - Connex part #: MR-8LM
  • 16-Pin Honda-type Feedback Connector (for Dynaserv DM Series):
    - Connex part #: MR-16LM
The following Dynaserv connectors are directly available from Compumotor:
  • 20-pin Fujutsu connector:
    - Compumotor part # 43-017077-01 (connector) and 43-017078-01 (cover)
  • 50-pin Fujutsu connector:
    - Compumotor part # 43-017079-01 (connector) and 43-017080-01 (cover)
NOTE: For diagrams, connection instructions, and other specific information on a particular connector, consult the User Guide for your particular Dynaserv model.
