Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Outputs on Position (OUTP Command)
Output On-Position (using the OUTP command) can only be used with the onboard outputs and not with the expanded brick outputs.
The difference is that the onboard outputs have comparators directly associated with them. These comparators are used for the Output On-Position. There is essentially no delay for an output on position because the outputs are tied directly to the comparators.
