Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Target Zone bit with Stepper
While using a stepper motor with the 6K, the "In Target Zone" bit in axis status will turn to NO after motion has occured. This is because the "In Target Zone" bit is for servo motors only and is not used in stepper motors, even when an encoder is used and its count enabled.
