Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Chopping frequency of the Gemini drive.
Below is the table of the PWM Switching Frequencies of the Gemini Drives.
Gemini GT stepper was fixed at 20kHz. It's output current was 5A for the GT-L5 and 8A for the GT-L8
