Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Fieldbus Data Transfer Rates
Profibus DP is able to transfer data at 12 Mbps.
DeviceNet can transfer data at 500 kBytes/sec.
Note - both the Profibus and DeviceNet options are discontinued and not available any longer.
