Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Daisy chaining GVs and GTs
GV and GT drives and/or drive/controllers may be daisy chained together without a problem. If sending a product specific command to daisy chained units the command must be addressed correctly to avoid generating error messages.
