Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Sequence Names Can Cause Problems.
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
When a sequence is defined,
DEL SETUP
DEF SETUP
{body}
END
the choice of name sometimes causes a problem. Names such as TEST or HOME (in place of SETUP) sometimes keep the program from running correctly. They are too similar to commands for the controller.
Nor can names begin with a number. 3MOVE does not work, but MOVE3 does. 3MOVE will cause the controller to choke and a RESET needs to be issued.
The controllers only recognize 6 letters for a sequence name. So, MOTION1 and MOTION2 are considered the same program by the controller (the controller will truncate both to be MOTION).
