Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Linker Error
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
Linker Error
If you have problems linking the 6000 library files to your C++ program using a Borland compiler the problem likely is the way Borland formats their library files. It is different from the way Microsoft formats them. Our product works well with MS but does not work at all with Borland. There is another utility offered by Borland that will convert the files in one step called "COFF2OMF":
http://www.digitalmars.com/eup.html
