Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Troubleshooting - Visual Basic run-time error 2147418107
If you are using the 6K's ComServer within a timer event inside a Visual Basic project, you may encounter this error:
"Run-time error '-2147418107 (80010005)':Automation error."
This error occurs because you cannot make a call to an ActiveX server from a timer until the previous timer event has finished. Please see the following web site for more details:
http://support.microsoft.com/support/kb/articles/Q176/3/99.asp
