Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Hardware - Flash Memory Limitation and Battery Backed RAM
Flash memory is used for the 6K’s operating system. It can be erased and re-downloaded a maximum of 100,000 times. Regular program and variable storage uses BBRAM, and allows an unlimited number of read/write operations.
