Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Troubleshooting - SSLex0105e: Invalid token, Line 1, Offset 10, <<
If you get this kind of error in Motion Planner editor, it means the editor cannot understand a character you have entered. This most often occurs when a cut-and-paste is used to place text in the editor from another source, and the character is not part of the standard ASCII set.
