Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base The GV and Linear Motors
The basic requirements of a Linear Servo Motor to be used with a GV drive are:
3-phase
120 degree Hall Effects
Linear Encoder
>1 mH Inductance
