Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base DR-Series vs DM-Series
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The Dynaservs come in two different series: the DR-Series and the DM-Series.
The DR-Series utilizes a Resolver for feedback while the DM-Series uses an Encoder.
DR-SERIES
The resolver is more rugged than the encoder and it is less expensive. However, it also provides a lower resolution.
DM-SERIES
The encoder provides a higher resolution, but it is more expensive.
