Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Software - How long does the 6K take to execute commands?
On average, the 6K takes about 2 ms to execute commands that are not within a compiled program. Logic statements take longer while basic setting commands take a shorter amount of time.
Programs compiled with the PCOMP command execute much more quickly because the computations are done before program execution.
