Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Gain Multipliers
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
Gain Multipliers
The gain multipliers can be used to multiply the value of the DC Gain (potentiometer) setting on the front panel of the Dynaserv drive. The DC Gain pot can be set for values of .5 to 5.5. There are two way to increase these values with a multiplication factor.
1. There is a jumper setting on JP1 labeled GAIN H. With the jumper ON, the DC Gain pot setting will be multiplied by 13.
2. There are DC gain multiplier circuitry that can be accessed on CN1(50 pin Honda connector). The circuit requires an external 5 to 24 VDC supply. Pins 34 & 35 is Gain Low(GL), 36 & 37 is Gain Medium(GM), and 37 & 38 is Gain High(GH). NOTE: Even numbers are + and odd numbers are GND.
DC Gain Multiplier Scaling
GHGMGLGAIN FACTOR*
HHH1
HHL4
HLH7
HLL10
LHH13
LHL16
LLH19
LLL22
*Mutiply the DC Gain pot setting by this value.
