Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SM Motors - SM motor cables -TQ , -MS, -GS versions
Cables do not come with the -MS, -TQ, or -GS versions of the SM and NeoMetric motors, they are purchased separately. The only motors that come with cables attached will have a 10, or 25 in the part number. The -FL version does not have a cable, but has flying leads instead.
For example: SM232AE-N10N
SM232AE-N25N
SM232AE-NFLN
