Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Setting the deadband on the VAC.
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • Parker Electronic Motion and Control Division (EMC) - Industrial Products Warranty
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
The deadband can in affect be set using the inband.
By placing a jumper across the B & C pins on the JU1 jumper, which is the kill-on-inband, and adjusting the inband with a potentiometer, a "deadband" can be created and adjusted.
