Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base My ARC-C or -D does not fit on my motor.
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • Parker Electronic Motion and Control Division (EMC) - Industrial Products Warranty
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
If the ARC is order with the -D option that contains the 106 Adapter & Coupling and it is going to be used with an S106-205, RS42, or TS42 motor, then one more part will need to be ordered. For the S106-205 and RS42 motors, the RS42 ENC PLATE is needed. For the TS42 motors, the TS42 ENC PLATE is needed.
The -C option that contains the 83 Adapter & Coupling requires similar parts. For the RS34 motors, use the RS34 ENC PLATE. For the TS34 motors, use the TS34 ENC PLATE.
