Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base How do I change the Btorq.dat file?
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
All of the motor data in the Sizing & Selection software is contained within the btorq.dat file. Given a different file, btorqnew.dat for example, the existing btorq.dat can be renamed and replaced.
If the Sizing software is in the C:\SIZING directory, then the btorq.dat file will be in the C:\SIZING directory as well.
Using some examples:
Rename btorq.dat to btorqold.dat. Put btorqnew.dat into the C:\SIZING directory and rename it to btorq.dat.
By changing this file, one may update the Sizing software or even size older motors such as the ones in the Sustaining file.
