Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Linearserv Lubricating Grease
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The specified lubricating grease for the Linearserv bearing are as follows:
LM1050/LM1100/LM5040/LM5090 - MaltemplePS No.2 (Kyodo Co.)
LM1300/LM5270 - AFB (THK) or Albenia EP2 (Shell Oil Co.)
Kyodo Yushi USA Inc.
51 Corporate Woods, 9393W. 110th St.
Suite 534
Overland Park, KS 66210
Tel: 913-451-6702
Fax: 913-451-6741
THK
Los Angeles, CA
Tel: 714-891-6752
Fax: 714-894-9315
Shell Oil Co.
One Shell Plaza, 900 Lousiana
Houston, TX 77002
Tel: 713-241-5064
Fax: 713-241-2855
