Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base OEM750 drive shutdown / remote input?
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000+
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products-
      • Battery OEM:010,070,650X-M2,670X/675X,750X-M2,770X
      • CE marking for the OEM 1000
      • Changing a OEM350X/650X/750X to an OEM350/650/750
      • Changing an OEM670X/675X to an OEM670T/675T
      • Changing the Direction of Steppers
      • Configuring OEM servo drives for BE motors
      • Current loop compensation resistor
      • DC Brushed Motor with the OEM670 & OEM 675
      • DC Brushed Motor with the OEM770
      • Do not Wire OEM300 in Series or Parallel
      • Enable in for the OEM750/750X
      • How do I find an OEM device address?
      • I cannot disable my OEM750.
      • Nested Loops in OEM and PDX
      • OEM Fault Input
      • OEM Products: Connector Part Numbers
      • OEM Resistor Kit
      • OEM Servo Motor Specifications
      • OEM350/OEM650 Product Change Notification
      • OEM670 Changing Directions
      • OEM67n peak current, resistor selection
      • OEM750 drive shutdown / remote input?
      • OEM750/OEM750X Connector Part Number
      • OEM750X Minimum Voltage Requirements
      • OEM750X on Power Up
      • OEM770 replaces the OEM670/675
      • OEM770 Resistor Kit
      • OEMZL4 replaced by ZETA4, OEMZL6 still available
      • Sequence Select Inputs (OEM750X)
      • TQ10 and OEM67n Hall Sensor Compatibility
      • TR Command in Basic X Products
      • Uploading in an X-language product.
      • What is the step pulse output width for OEM010?
      • X Language Products - Communication via RS232
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
The OEM750 has a remote input. To use it as a shutdown input one should wire a short between the remote and current screw terminals on the drive. It is important to remember that this function does not shut down the chopping amplifier. Rather it simply regulates 0 amps. This means that the motor will cog if the customer trys to turn the rotor after activating the remote input. The chopper will regulate equal and oposite current that is induced by the regeneration of the motor. Also, the chopper will make as much electrical noise as it would if the remote input is not active.
To get a true shutdown input on the OEM750, you will have to purchase a custom version of the OEM750, p/n:
CP*OEM750 10639
updated 2/3/2015 nmc
