Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SM Motors - SM Series Size 16 Connection Diagram
Here is the SM Series Size 16 Connection Diagram
Motor Connection Encoder/Hall Feedback Connection
Designation Wire Color Designation Wire Color
PhaseA Red/Yellow Vcc Red
PhaseB White/Yellow Ground Black
PhaseC Black/Yellow Ch A+ White
Ground Green/Yellow Ch A- Yellow
Temp Orange/Yellow or Yellow Ch B+ Green
Temp Orange/Yellow or Yellow Ch B- Blue
Shield Index+ Orange
Index- Brown
Hall-Effect
Hall Gnd White/Green
Hall +5 White/Blue
Hall 1 White/Brown
Hall 2 White/Orange
Hall 3 White/Violet
Brake Red/Blue
Brake Red/Blue
