Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Offset voltage on the Compumotor Plus
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
The Compumotor Plus does not have any hardware or software that would allow a user to adjust for an offset voltage on the command signal.
How it works
On power up the Compumotor Plus references the command signal to ground and recalculates the offset. Once this is complete the offset can not be changed.
