Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Misc - Motion Planner Minimum Requirements (not compatible with Win10 or later)
The read-me file in Motion Planner states that it requires a Pentium processor with a speed of 166 MHz. This is what is recommended, but a 486 does work...very, very slowly. It just has to be a 32-bit operating system, with a CD-ROM drive.
