Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Heat Dissipation within Enclosures
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • Parker Electronic Motion and Control Division (EMC) - Industrial Products Warranty
    • QM Series Motor Information
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
To determine if ventilation is needed for a particular enclosure, add the total heat dissipation of all heat sources within the cabinet, determine the ambient temperature, determine maximum internal temperature, choose a cabinet size, and then contact your cabinet distributor.
They generally have a software program, much like Compumotor Sizing Software, that determines if external cooling is required. If it is required, you may use the following equation to determine how much cooling is recommended.
cfm = (3160)(kW)/Delta T
kW = heat dissipated in the enclosure by a power source, kW
Delta T = temperature difference of exhaust air and incoming ambient
