Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Error Code #3 on Dynaserv
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
On the Dynaserv, Error #3 is an encoder error and 0008 is most likely to be caused by electrical noise.
From our experience, these symptoms can be rectified by separating the power and encoder cable or rearranging the cable route to avoid noise.
