Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Linearserv Cable Bending Radius
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
The cable used for the Linearserv is a robot cable and has a bending radius (at the center of the cable) of 55mm or more. According to the cable manufactured data, the cable was able to go through bending test of for 10,000,000 times at 90 degrees beding.
