Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SM Motors - Brake specifications for the SM and N0 motors
Brake specifications for the SM and N0 motors:
Electrically Released Brake
16 Frame 23 Frame 70mm, 34 Frame 92mm
Static rated torque N/A 10 in-lb 24 in-lb 72 in-lb
Coil voltage N/A 24VDC 24VDC 24VDC
Coil current N/A .38 A .8 A .52 A
Weight N/A .7 lb 1.0 lb 2.5 lb
Inertia (lb-in-sec?) N/A .0000187 .000038 .00015
