Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Why is the motor not moving when I command it to?
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
If the Controller and Drive are separate units, make sure the DRFLVL is set correctly. Also make sure that the drive is enabled with the DRIVE command. If they are in the same unit (APEX615n and ZETA61XX units), then the DRFLVL command is invalid.
Servos: make sure that the Enable (ENBL) pin is grounded.
Steppers: make sure that the P-CUT pin is grounded.
Type the command TASF. This command provides good information about the status of the controller.
Are either bits 17 or 18 on TAS high?
YES: A hard limit is hit.
Are Hard Limits being used?
YES: Check to see if the load is at a limit; if it is not, then check to make sure the wiring is correct.
NO: Disable the Hard Limits with the LH command.
