Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base What does the Error Log contain?
The Error Log is capable of recording the 10 most recent errors with time stamp. Once an error occurs, a snapshot of the status registers, drive temperature, and motor temperature is taken. The information wil be retained upon any power loss.
