Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Establishing Communication with the PDX
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000+
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • Digiplan BD, BDS, BDHX,BL, BLX,BLHX, PDS, PDX, PDHX-
      • Battery for the PDX &TQ10X Drive
      • Battery Replacement for BDHX,BLX,BLHX,PDHX, X150
      • BL, BLX, BLH, BLHX, ML Suggested Replacements
      • BLHX Error
      • BLHX Error #25
      • BLHX Part Number
      • BLHX Registration Speed
      • BLX Outputs.
      • Can I use a ML motor in place of a MD motor?
      • Error code 3 - Memory map changed
      • Establishing Communication with the PDX
      • No Communication with the BDHX?
      • No motion? Check motor resolution for the PDX
      • PDHX-E Troubleshooting Codes.
      • PDHX15E Self Test
      • PDS Power Dump Option(-D)
      • PDS Replacement
      • PDS13 PDS15 PDX13 PDX15 Connector Part Numbers
      • PDX Replacement
      • Removal of RS485 in PDHX-E and BDHX-E
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
Here are two important tips that will help you establish communication with the PDX. After you have connected in terminal mode using X-ware, you will notice that you do not see a prompt ">" like some of the other x-ware products. This is normal. The PDX does not return a prompt at the terminal.
In order to verify your communication with PDX you need to know that the default address for the PDX is 8. Unlike some the other X products which default to 1, the PDX has three hardware address select inputs on the 25 pin connector which if left untouched result in a address of 8. In order to get a response from the unit you must precede the command with a valid device address. One of the best commands to help determine a devices address is the R command. Issuing 8R(be sure to use capital letters) should give you a response of *R, *S,*B , *C . If you do not see a response to this, the unit may have been set to a different address in which case you will need to try a different address with the R command, like 1R,2R, 3R until you receive a response.
