Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base 6K Software - Where is the Communication (com6srvr) server located?
Motion Planner 2.1 does not install the comserver in the root directory of Motion planner. The file is located in the Windows >System directory. The full filename is com6srvr.exe
