Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base SetNTMultiCardAddress doc error
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
There is an error in the documentation (6000PG) for the SetNTMultiCardAddress function of the nt6400.dll. The function should be declared as
Declare function SetNTMultiCardAddress Lib "nt6400.dll"
(ByVal address as Long) as Boolean
The most common symptom of this error is that only the first card (lowest address) in your system will be recognized, regardless of what addresses are used, or what order you attempt to initialize them in.
