Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Dynaserv Heat Dissipation Caculations
    • Dynaserv (Discontinued)-
      • DM1004B/C Common Questions
      • DR-Series vs DM-Series
      • Dynaserv Bandwidth
      • Dynaserv Cable Length
      • Dynaserv Flying Lead Cable
      • Dynaserv G3 Drive Drawings
      • Dynaserv Runout Options
      • Dynaserv Settling Time
      • Error Code #3 on Dynaserv
      • G3 to 6K Basic Setup
      • Gain Multipliers
      • Line Filter for DM1050A
      • Minimum bend radius
      • Motor and AC Mains Filter
      • OEM070 with Dynaserv
This calculation can be used when designing an enclosure for the Dynaserv motor and drive.
Basic heat from the drive will vary between 50 - 70 watts depending on the duty cycle.
Motor heat can be calculated with the following formula:
T(Nm) * 2pi * n(rps) * 1/.7 = watts
T = motor peak torque
n = operating speed in revolutions per second (rps)
