Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Downloading Programs in a Daisy Chain
  • Legacy (Discontinued)-
    • 4000+
    • Compax and SV+
    • 6000-
      • AT6000 Auxiliary Cables
      • AT6000 Product Issues
      • AT6XXX
      • Backing up 6000 Programs
      • Bad DLL Calling Convention
      • DDE 6000 and Excel
      • HOMLVL command
      • Linker Error
      • Minimum files for AT card
      • Model 6201 Information
      • Motion Architect and WinRT
      • ReceiveFile method bug
      • What is WinRT anyway?
    • APEX & APEX615x+
    • BLOK+
    • Compucam+
    • iBE+
    • L20+
    • MP-FLX and FLX+
    • MPA Servo Drives+
    • Motion Architect+
    • PC21+
    • RP240+
    • S/SX Drives+
    • OEM Products+
    • SLVD & HPD+
    • TBF & TBN Servo Drives+
    • TQ10 & TQ10X+
    • XWare / X Language+
    • Z ZX ZXF Drives+
    • Retired Products
When the 6000 products are in a daisy chain, you could run into problems if you try to download programs to these units. This is because the flow control does not work in the daisy chain. Therefore, if your progam exceeds the buffer limit of the product(400 Characters), some commands could get lost. Below are some recommendations to get this to work.
1. Download programs to each controller individually without the daisy chain.
2. Only download one program at a time instead of all your programs at once.
3. Use a terminal that you can add delays after each line of the program.
