Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Does the Gemini drive have a test mode?
Yes, when you are connected to the Gemini drive the DMODE13 command puts the Gemini drive in Autorun mode. This rotates the motor at 1 rps.
