Search
Sign in
Aerospace
Climate Control
Electromechanical Group
Filtration
Fluid and Gas Handling
Hydraulics
IoT
Pneumatics
Process Control
Sealing and Shielding
Parker Indego
Blogs
Forums
Knowledge Bases
Aerospace
Climate Control
Filtration
Hydraulics
IoT
Pneumatics
Process Control
Parker Indego
Blogs
Forums
Knowledge Bases
Search
User
Site
Search
User
Home
Resolution of the Gemini command signal.
More
Cancel
Members
Sub Groups
More
Cancel
New
Virtual Engineer
Aries Drive (Discontinued)
Compax3
Dynaserv (Discontinued)
Gemini (Legacy)
24 Volt Keep Alive
Analog input on GV6, GV6K, GT6, GT6K
Audible Noise in Stepper Motors
Cable breakout modules for the Gemini
Can I run the MX80L using a Gemini Drive?
Can the Gemini Products take a DC voltage supply?
Changing Motor direction on the GV6 or GT6
Chopping frequency of the Gemini drive.
Connector Part Numbers
Controller to GV Cables
Currently Released Gemini Drive Products
Daisy chaining GVs and GTs
Digital Notch Filters
Does the Gemini drive have a test mode?
Downloading the OS to my Gem6K locks up.
Encoder Motors Work with Gemini Resolver units
ERES /ORES Relationship for Gemini GV Products
GC-SDA Fault output is not really the fault output
GEM-VM50 screw-terminal breakout dimensions
Gem6K (GV6K & GT6K) Family Letter of Volatility
Gemini MaxPlus (MPM) Resolver Option 1 Connection
Gemini - Downloading in
Gemini - MaxPlus (MPM) Encoder Option 1 Connection
Gemini - MaxPlus (MPM) Encoder Option 5 Connection
Gemini Analog Input Deadband
Gemini Analog Output A now dithers
Gemini GV - Resolver to Encoder Signal Conversion
Gemini GV6 & GT6 RS232 Daisy-Chaining ERRLVL
Gemini Maximum Frequency Input and Output
Gemini OS Download Failures
Gemini Step & Direction Inputs
Gemini Update Rates.
Gemini Variable Resolution
Gemini: 400LXR Tuning
Gemini: ASCII or Binary?
Gemini: VIDEO: express basics training: How to Connect Ethernet (includes Win7)
Getting the letter a with a ~ over it in Motion Planner Terminal
GFB-KIT Pinout
GV Cable Diameters.
GV6K & GT6K cannot Follow Analog Onboard Input
GV6K Tuning in Position Mode with Motion Planner
Hall State Checking on Gemini Products
Hall-less Startup on Gemini
I cannot communicate with my GEM-6K.
Limits on Gemini
MS cable option vs. GS cable option
OS 1.70 Additions
Replacing the Gemini GC-SDA
RESET command in STARTP program
RS232 Troubleshooting for the Geminis
Step & Direction Output
TASX Bit 1 -- Motor Temperature Fault
TASX Bit 10 - Bridge Fault (Hardware)
TASX Bit 11 -- Bridge Over-Temp Fault (Software)
TASX Bit 12 -- Over-Voltage Fault
TASX Bit 17 -- Stall Detected
TASX Bit 18 -- Override mode
TASX Bit 19 -- Foldback Active
TASX Bit 2 -- Low Voltage Fault
TASX Bit 20 -- Power Dissipation Circuit Active
TASX Bit 21 -- Bad Hall State Detected
TASX Bit 22 -- Unrecognized Hardware Detected
TASX Bit 23 -- User Fault Input Active
TASX Bit 24 -- Keep Alive Circuit Active
TASX Bit 25 -- Power Dissipation Circuit Fault
TASX Bit 28 -- Motor Configuration Warning
TASX Bit 29 -- ORES Failure
TASX Bit 3 -- Drive Temperature Fault
TASX Bit 30 -- Motor Thermal Model
TASX Bit 31 -- Commanded Torque Limit Hit
TASX Bit 5 -- Encoder/Resolver Failed
TASX Bit 7 -- Motor Configuration Error
TASX Bit 8 -- Incoming Pulses
TASX Bit 9 -- Velocity Error Limit Exceeded
The GV and Linear Motors
Tuning a GV6K GV6 or GV in Position Mode
Tuning GV or GV6 drives with large inertia loads.
Tuning the Gemini in Position Mode
Tuning the Gemini in Position Mode.
Tuning the Gemini in Torque Mode.
Tuning the Gemini in Velocity Mode.
Using Gemini with Empire Magnetics Step Motors
VIDEO: Basics Training: GV or GT drives
VIDEO: Basics training: GV6 or GT6 drive controllers
VIDEO: Basics training: GV6K or GT6K drive controllers
What are Q and D currents?
What does the Error Log contain?
What drives can work with a DC brushed motor?
What happens in Keep Alive mode?
What motors with what Gemini drive?
What recognitions does the Gemini GV have?
What replaces the Gemini GT stepper drive?
What replaces the Gemini GT6 stepper drive/controller?
What replaces the Gemini GT6K stepper drive/controller?
Which Motors Work with GV-L Drives? GV-U Drives?
Which rotation is considered positive for GV6K?
Why doesn't my Drive I/O cable tighten down securely when using the jackscrews?
Why will my PAD and PED not update on the Gemini?
Z channel output from the Gemini?
IPA Drive/Controller
P Series
PSD - High Performance Servo Drive
ViX (Legacy)
Gearheads
AC/DC Industrial Drives
Servo Motors
Step Motors
Linear and Rotary Positioners
Electric Cylinders
T-Slot Aluminum Framing
C3 + Xpress + ETH
Legacy (Discontinued)
Other
Share
More
Cancel
Home
Aerospace
Supplier Resource Center
Climate Control
Electromechanical – Mobile
Filtration
Hydraulics
IoT
Mobile IoT
Pneumatics
Pneumatic Industrial
Pneumatics Mobile
Process Control
Parker Indego
Parker Indego Instructors
Parker Indego Therapists
Parker Indego Distributors
Community Blogs
Community Forums
Community Knowledge Bases
The Gemini uses a 12 bit converter for its command signal.
Share
History
More
Cancel
Sign in to reply
