Home Technologies Electromechanical Group Electromechanical - Industrial Electromechanical Industrial Knowledge Base Inertia Ratio
  • Other-
    • -E Motor Option
    • C/CX Suggested Replacements
    • Cage Code
    • Controller Cable Drawings
    • Custom Products
    • Daisy chaining AR-C
    • Drive Input Power
    • Dumping the 3000 memory.
    • EDC TDC XDC VRP PMC
    • Encoder or Resolver?
    • Ferrite absorber
    • How Much Power Do I Need?
    • Inertia Ratio
    • KH/KS Error 62
    • KH/KS Motors
    • QM Series Motor Information
    • Smart Encoder Compatibility
    • Software for the SV
    • Torque Margin
    • Transformer Specs
    • Upgrading A/AX Systems
    • What is CE, EMC and LVD?
Inertia Ratio
INERTIA RATIO
J load / J motor
J load = inertia of load as seen by the motor.
J motor = inertia of the rotor of the motor.
We recommend for performance reasons that the Inertia Ratio be equal to or less than the following:
Stepper: 10
Servos: 20
Dynaserv: 50 to 100
The ideal Inertia Ratio is a 1:1 ratio. This is when the motor is the most efficient. Less that a 1:1 ratio is slightly less efficient that a 1:1 ratio.
